orifice plates
gerry gill
Member Posts: 3,078
out of brass shim stock i get from MSCdirect..we tried contacting tunstall once and were treated rudely..won't deal with them now.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
orifice plates
Anyone know where one can buy blank orifice plates? Thanks!
I believe Tunstall
has them- at least real orifice plates for steam and probably gravity HW... maybe they can sell you some blanks?
Or if your needs differ, a spot of brazing and a re-drill? Just a thought.
http://www.tunstall-inc.com/inletorifice.html"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
I have...
made my own in the past from copper dwv test caps. They are made from very thin copper sheet and can easily be cut to size and drilled.
Just a thought,
JimThere was an error rendering this rich post.
Thanks Jim
that`s a great idea, next time I will remember that! BTW- How do you figure the right hole size?
Dave0 -
Well Dave...
i'm sure there is a way to determine orifice size as to the EDR of the radiator, but the couple of times I did it I just used trial and error.
Using some orifice drills, I started small and worked up until I got the rad hot most of the way across. Didn't take much.
Good luck,
Thanks guys
another thing I WILL remember!
Dave0 -
Tunstall
Truly sorry you had a bad time with Tunstall. So far, they have treated us very well. Their products are good and they ship fast. They will custom make rebuild parts for obsolete steam stuff. I will call them about orifice plates, but I suspect that since they are in the business of selling traps, they may not sell orifices. They don't seem to list them in their catalog.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
