Electric boilers and low temp
Terry Larsell
Member Posts: 54
I'm getting requests for electric radiant and I was wondering how electric boilers like low temp return water. Will this be a problem or should I protect it.
The current rate in Hood River OR is about 4.6 cents so I'm have trouble showing any savings with NG.
So long as it
is installed in a non-condensing environment (meaning not in a dripping humid basement where the circulating water temperature might be below dewpoint) I do not see a problem. Key is to keep sensible moisture out of the electronics. With water room temperature and above, I do not see a problem. Electric water heaters, remember, take 40 degree water without complaint."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
One point to keep in mind with most electric boilers
is a flow switch to trip on the elements. They need flow before you start kicking on elements.
Tank type water hesaters with low or medium density wattage elements are not a problem, flow wise, however.
hot rod
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
