Polypropylene venting
Derheatmeister
Derheatmeister Member Posts: 1,647
Check Ipex, they have a Polypropylene vent system,But i am not sure if it will be available since they no longer are serving the N American market needs.
Also baxi luna has PP venting piping with adapters from 3 and 4 inch to metric .
Or SS can be used.. Richard
  • Mike Dunn
    Mike Dunn Member Posts: 189
    Sorry
    to make a new thread on this, but who makes venting systems out of this material. (Polypropylene)
    Mike Dunn
  • I dont believe they make
    a venting system but they make polypropylene pipe.....http://www.aquathermpipe.com/
  • Burnham uses
    Polyproylene, I am sure they wpould be able to steer you to the manufacturer.
  • Mike Dunn
    Tim
    I did not see any polypropylene venting on Burnham's website. Do you know if they are selling it with their new condensing boilers?
  • Ron Gillen
    Ron Gillen Member Posts: 124
    Viessmann
    The Viessmann coaxial vent for the Vitodens is polypropylene pipe for the flue with an aluminum outer pipe. Only one I'm aware of.
  • Perry_5
    Perry_5 Member Posts: 141
    Pay attention to the temperature ratings
    Not all polypropylene is created the same.
    I did some research and found the following offered:
    Standard polypropylene pipe & fittings: Rated for up to 180 F Available in many "plastic" catalogs and from many industrial suppliers.
    Laboratory Drain polypropylene $ fittings: Rated for up to 212 F Available from one company (the company that makes this system).
    Viessmann polypropylene boiler co-axial vent system: Rated for up to 248 F.
    You are looking for the 248 F (or similar) rating for a boiler vent system.
    Not sure where to find the 248 F (or similar) material - but as several other companies are offering co-axial vent systems someone must be making it.
    Perry
  • Derheatmeister
    Perry..Yes
  • Mike I am pretty
    sure they are it is the same stuff used in Europe. I am going down to my training center this afternoon and will check the unit I have as to what the material is. I will get back to you.
  • Crown boiler
    Uses it for their bimini, it comes with the boiler but more is available if needed..http://www.crownboiler.com/
  • kpc_47
    kpc_47 Member Posts: 3
    boilers that....
    use it that I know of are... Burnham Alpine, Embassy Onex, Crown Bimini...
    This is their answer to PVC which the PVC guys state is not approved for venting boilers.
  • Doug_7
    Doug_7 Member Posts: 266
    IPEX in Canada
    Since when are IPEX in Canada no longer are serving the N American market needs ?
    I heard about the Kitec water piping system recall, but that is only one small product line.
    Doug
  • Mike I will e-mail
    Burnham.
  • Doug_7
    Fire Rating Question
    I suspect that when it comes to plastic flue pipes, that is a little more to it than the temperature rating of the pipe.
    Fire rating of the pipe may also be necessary depending on local fire / building codes. I suspect this is why PVC has the plumbing / drainage market sewn up.
    Doug
  • I got the e-mail
    back as rejected by your server as being too large. Burnham does use polypropylene on there Freedom CM in a concentric vent.
