Viega???????????
Ken_40
Ken_40 Member Posts: 1,310
White Paper for submission to ASHRAE.
Based on what we know, the fittings can be problematic. Brands, machines and the definition of what is or isn't a "leak," is still under review.
The manufacturer's manner of dealing with the problem and supporting documentation to that end, suggests other connecting methods should be considered.
  • Jeff Elston
    Jeff Elston Member Posts: 289
    There or not there
    What is your experience with the Viega Propress fittings?
    Are they there when you want them to be?
  • Perry_3
    Perry_3 Member Posts: 498
    Search for a thread tittled \"Press Fittings\"
    I think that's the one (really long too). If not others might be able to help with the tittle.
    After you read that - and the company response - You are free to decide.
    Perry
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,577
    Others
    can say what they want.I've installed thousands both Viega and Elkhart using a corded REMS tool, never a leak other than operator error.
  • Tim Doran_4
    Tim Doran_4 Member Posts: 138
    Different configuration
    The pro press has a ring of copper outside of the o-ring and the Elkhart does not. Any difference in the way you press them, different tools?
    Tim D.
  • Weezbo
    Weezbo Member Posts: 6,231
    i saw some installed on a condensate line....
    something tells me that is not an ideal situation...
  • ScottMP
    ScottMP Member Posts: 5,882
    Weezbo and Ken
    Weesy, any copper on a condesate line is bad news.
    Ken, How many others came out on the LONG thread to show the problems they have had with the product ???
    I have installed thousands of fitting with no failure to date.
    Scott
  • Glenn Sossin_2
    Glenn Sossin_2 Member Posts: 592
    ProPress
    We sell the line carry - everything they make up to 4". Expensive but a big labor savings. No FLux, No Gas, No Torch, No Burns, No Smoke Permits,No Leaks, etc.
    Easy to use. Absolutely love training contractors on the job. We have a loaner tool we let them use for 1 day - they pay for the fittings. We provide someone to help train them on site at the job. Usually convert 7 out of 8 contractors who try it. Makes for a beautiful boiler room.
    Nothing like a 4" line repair with water flowing out of it. Check out the pics. Note The pipe should be cleaned and reamed before connections are made.
    Glenn
  • Glenn Sossin_2
    ProPress Ridgid vs Elkhart
    Elkhart and Ridgid/Viega are pressed the same way with the same jaws. There is a relatively new line of large diameter fittings called XL-C. 21/2" -4", - are made out of copper. Somewhat less expensive but require a different set of jaws. Elkahart fittings are made of copper also but will use the older style XL jaws. Sell & have used both. No issues
  • ditto
    Same experience here as Scott. Only one leaked & that was our fault. Did a Cheeseburger in Paradise restaurant with thousands of PP joints more than a year ago & not one single problem to date. Lots of hydronic installs too. Quickie ball valve install in a hotel to isolate a commercial water heater - no lost room revenue, which they really appreciated.
  • heatboy
    heatboy Member Posts: 1,468
    ditto x 2
    I have been using PP for over 4 years with no issues, other than operator error, to date. Hundreds of fittings, from new construction to service on old copper. I'll never go back.
    hb
  • hr
    hr Member Posts: 6,106
    Ouch, is that an ear ring
    on the one mechanic? Looks like it is ready to get caught on the ceiling grid work :)
    hot rod
