Geothermal storage (buffer) tanks
Dave_4
Dave_4 Member Posts: 1,404
I've asked about this before and gotten conflicting responses - Is an adapter from the element straight thread to NPT necessary? I think someone said they've been using regular NPT male fittings with plety of dope and had no problems. Any other opinions one way or another?
  • RADSTEVE_2
    RADSTEVE_2 Member Posts: 9
    Thermal Storage Tanks
    We are getting into the DX Geathermal market. Where can we find a source for thermal storage (buffer) tanks. We deal with Heat Transfer Products but they don't have a unit with two inneys and two outeys without the coil.
  • Paul Rohrs_4
    Paul Rohrs_4 Member Posts: 466
    Geo Buffer Tanks
    One of the leading geothermal supply houses in our area packages Marathon water heaters as their buffer tanks. After removing the elements,they have a (spendy) brass adapter that threads into the element tappings. It seems to be working well for us.
    Regards,
    PR
  • Dick Barnett
    Dick Barnett Member Posts: 1
    Buffer
    See www.cemline.com for a hot water buffer tank and/or chilled water buffer tank (different design criteria). A 60 gallon unit has just been introduced.
  • hr
    hr Member Posts: 6,106
    Some of the new \"smart\" plastic tank water heaters
    have an odd thread on their elements. For those you would need some adapter.
    For a basic plain 1" threaded element I have used a copper 1" male adapter or a 1" threaded nipple without any leaks problems.
    I'm not sure this is a "factory approved" connection. But plenty of plumbers use this method.
    I know Lochinvar has added a bunch of storage tanks to their lineup. Try them also.
    hot rod
