Wirsbo tech in Southern Westchester County
Jamie_6
Jamie_6 Member Posts: 710
West Chester County, Pennsylvania?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Stevel_3
    Stevel_3 Member Posts: 2
    Baffling problems with 6 yrs old Wirsbo system
    There are over 25 zone valves, four circulaating pumps, seperate headers for ceramic radiant, wood floor radiant, pex fed cast iron radiators. Installer has disappeared. Currnet problems revolve around erratic heat to wood floor radiant areas controlled by a mixing valve that failed. Need someone experienced with wirsbo controls, valves circuit boards circa 2000.
  • Dave Holdorf_2
    Dave Holdorf_2 Member Posts: 30
    Looking for Help?
    Stevel-
    Give me a call, I am the East Technical Representative for Uponor (formerly Wirsbo) 631-909-2494.
    I can help you find a qualified contractor near you.
  • Bob Bona_4
    where
    are you in Westchester? I'm based in Stamford.
  • Stevel_3
    wirsbo in westchester county NY
    My post last week seeking counsel was answered by Dave Holdorf, Wirsbo engineer and East Coast trouble shooter. Thanks to Dave for coming by the house, (after an all night drive from Bangor Maine) bringing with him Ed Manley, the installer and making some great suggestions. Once Ed locates and installs an outdated mixing valve and purges the system, I expect that all will be in order. Thanks again Dave for great follow-up and service.
