Usin a Taco ZVC406EXP
john p_2
Member Posts: 367
Have one left over zone on myTaco zone control panel and want to know if I could use it to power the fans on two hot water unit heaters in my garage. I already ran stat wires and connected a seperate zone valve to it for the heaters.
why not...
it should be fine....0 -
I think
you want 2 L6006C-1018 Honeywell strap-on aquastats for that function, line voltage to start the fan when the SWT hits an acceptable temp. The ZVC can't do that.
Jed0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
