Trap Primer
Gary_7
Gary_7 Member Posts: 25
MiFab M2-500 with a PPP DU2.
Gary
  • Gary_7
    Trap Primer
    Im going to install a trap primer with a distribution unit for 2 floor drains. The manufacturer states that the DU to the trap must be at least 1/2" copper only. I want to use pex for its ease of installation. Anyone have any thoughts? Should I avoid using pex? Why? I don't see the difference or the benefit of copper.
    Thanks
    Gary
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    What brand....
    ...trap primer is it? I've never heard of such a requirement.
    I always use 1/2" pvc, especially when it will be buried in the concrete.
    Starch
  • Big Ed
    Big Ed Member Posts: 1,117
    pex
    Depends on the town.Drop a dime to the local plumbing department....But since the manufacture stated copper I would dought the town would stick their necks out.
    Any emergancy drain that is connected to the waste line needs a primer.The trap will dry up with lack of use...
  • shawn_10
    shawn_10 Member Posts: 28
    Here is a devicethat is approved in ma.Check with your local codes this is a great invention.http://www.trapguard.com/
  • Constantin
    Constantin Member Posts: 3,796
    Agree... Have 3 and they work well
    ... much better solution than a trap primer, IMO. Found the product at ISH and confirmed with local inspector that it's approved.
    Just wish I had found it before we poured the basement slab, we would have had floor drains then... oh well.
