Sand instead of Concrete/Gypcrete??
Ericjeeper
Member Posts: 179
sand is so hot on top you can barely endure the pain. Then wiggle your feet down into the sand.. wahlah. instant relief. Sand is a very poor conductor of heat. Now Crushed limestone on the otherhand.. will have to wiggle em in quite a bit deeper to reach a cooler point.
Alternative Overpour
I have a contractor, actually the architect who refuses to pour concrete or gypcrete on top of a subfloor. We do quite a few jobs a year with them and on previous projects, have done dry systems ranging from Climate Panel to just an air space between sleepers. My question is, has anybody installed a dry system between sleepers and poured sand on top? I have heard of it, but never seen or done it. If so, are there special types of sand to use? Any information would be greatly appreciated.
Ernie Bogue
Master Hydronics LLC0 -
This \"idea\" pops....
up every two months....More of an "old wives tale" ...still is a bad idea...it will insulate more than anything. A better idea would be plates on top of the floor w/ sleepers.kpc
sand
Thank you! I love your explanation. I get this question every week. We are a Rapid Floor Gypsum concrete applicator and I hear this shortcut weekly. Not only doesn't it conduct heat well but it will be a dusty mess in your house forever. Picture an hour glass- OK now picture your house as the structure drys out and settles. Yea not pretty is it. Leave the sand outside in the sandbox.0 -
Ant Farm
Might I suggest covering the floor with plexiglass? within a couple of years you may be able to charge admission to the worlds largest ant farm!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
