Single loop baseboard - common return path
Uni R_4
Member Posts: 6
http://www.slantfin.com/documents/103.pdf -- page 15
The fins go on the bottom.
Single loop baseboard - common return path question
We had a plumber install hw baseboard in a bonus room over our garage. It is a single loop, on it's own circulator. Due to the configuration of the room, and pre-existing construction, it is a single loop with the physical return path being the same as the supply path. He installed the loop such that within each radiator enclosure, the hot water from the furnace is going through the pipes WITHOUT the fins, and the return is going through the pipes WITH the fins. The pipe WITHOUT the fins is physically on top of the pipe WITH the fins. We questioned him on this and he said that is how it should be. It does not make any sense to us - can someone please comment on how this loop should be configured - should the return be on the top or bottom within the radiator enclosure, and should the hot water from the furnace be going through the pipe with the fins, or without the fins? Thanks in advance for any insight.0 -
it won't work
It won't work if you have a furance... Will works if you have a BOILER.....0 -
It should
work fine either way.0 -
In my opinion it is 6 to one, half a dozen to another,.. Any heat loss from the pipe going above the fins will still get out of the baseboard enclosure in the form of a convective current.
It's fine.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
Yes it will work either way
annd I have done it this way sometimes just to get the hottest water to the futherest point first.0 -
Yes it will work either way , heat is heat
- 167 Indoor-Air Quality
