Single loop baseboard - common return path
Uni R_4
Uni R_4 Member Posts: 6
http://www.slantfin.com/documents/103.pdf -- page 15
The fins go on the bottom.
  • bsitsis
    bsitsis Member Posts: 1
    Single loop baseboard - common return path question
    We had a plumber install hw baseboard in a bonus room over our garage. It is a single loop, on it's own circulator. Due to the configuration of the room, and pre-existing construction, it is a single loop with the physical return path being the same as the supply path. He installed the loop such that within each radiator enclosure, the hot water from the furnace is going through the pipes WITHOUT the fins, and the return is going through the pipes WITH the fins. The pipe WITHOUT the fins is physically on top of the pipe WITH the fins. We questioned him on this and he said that is how it should be. It does not make any sense to us - can someone please comment on how this loop should be configured - should the return be on the top or bottom within the radiator enclosure, and should the hot water from the furnace be going through the pipe with the fins, or without the fins? Thanks in advance for any insight.
  • it won't work
    It won't work if you have a furance... Will works if you have a BOILER.....
  • bob_50
    bob_50 Member Posts: 306
    It should
    work fine either way.
  • Norm Harvey
    Norm Harvey Member Posts: 684
    In my opinion it is 6 to one, half a dozen to another,.. Any heat loss from the pipe going above the fins will still get out of the baseboard enclosure in the form of a convective current.
    It's fine.
  • brucewo1b
    brucewo1b Member Posts: 638
    Yes it will work either way
    annd I have done it this way sometimes just to get the hottest water to the futherest point first.
  • John@Reliable_13
    John@Reliable_13 Member Posts: 34
    Yes it will work either way , heat is heat
