Munchikin LP/nat gas
Dof3
Member Posts: 120
I have a 140 Munchkin with a Dungs gas valve. I need to convert it to LP gas. Is the Honeywell conversion the same as the Dungs conversion. I ordered the kit and they sent the Honeywell. I was just wondering if the disc orfice will fit the Dungs. Thanks for any help!!
John
John
No, they are not the same
the honeywell kit is not the same as the dungs kit. The part number for the dungs kit, for a 140M natural to LP is 7250P-439.
Chuck Shaw
Technical Support Dept
Heat Transfer Products0 -
Thanks!
Thank you very much Chuck. When I order the LP kit will the gas valve type show up in the serial number?0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
