Munchikin LP/nat gas
Dof3
Dof3 Member Posts: 120
I have a 140 Munchkin with a Dungs gas valve. I need to convert it to LP gas. Is the Honeywell conversion the same as the Dungs conversion. I ordered the kit and they sent the Honeywell. I was just wondering if the disc orfice will fit the Dungs. Thanks for any help!!
John
  • chuck shaw
    chuck shaw Member Posts: 584
    No, they are not the same
    the honeywell kit is not the same as the dungs kit. The part number for the dungs kit, for a 140M natural to LP is 7250P-439.
    Chuck Shaw
    Technical Support Dept
    Heat Transfer Products
  • Dof3
    Thanks!
    Thank you very much Chuck. When I order the LP kit will the gas valve type show up in the serial number?
