Heatpump Help
Big Idahoan
Member Posts: 43
We are working with a customer to retro-fit radiant into their home. They have an existing heat pump and they would like us to incorporate it into the radiant system. We haven't worked with a heat pump before and need some help getting information on heat pumps, and how to use them with radiant heat. Any info we could get from fellow wallies would be great.
Is it safe to assume...
Is it safe to assume that the existing heat pump is being used as part of a forced air system and you are attempting to use it in conjunction with the new radiant portion of the project?0 -
The previous system using the heat pump was a forced air system.0
- 167 Indoor-Air Quality
