Heatpump Help
We are working with a customer to retro-fit radiant into their home. They have an existing heat pump and they would like us to incorporate it into the radiant system. We haven't worked with a heat pump before and need some help getting information on heat pumps, and how to use them with radiant heat. Any info we could get from fellow wallies would be great.
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    Is it safe to assume...
    Is it safe to assume that the existing heat pump is being used as part of a forced air system and you are attempting to use it in conjunction with the new radiant portion of the project?
  • Big Idahoan
    Big Idahoan Member Posts: 43
    The previous system using the heat pump was a forced air system.
