sewage ejection pump noisy
jeff_25
jeff_25 Member Posts: 110
try moving the check valve higher up so the water above it does not slam back down on it
  • s.brown
    s.brown Member Posts: 8
    noisy sewage pump
    I have a plumbing question re: a loud banging noise right after a sewage pump has pumped. The pump float will cycle the pump to pump and right after it is finished the 2" ABS makes a loud banging noise. We replaced the combo check/ball valve to see if this would help but it didn't. The 2" ABS on the outlet is typical where it rises approx. 6' vertically and 90's across horizontally 5' and connects into the 3" ABS to the septic connection. Is there any way of eliminating this banging?
  • s.brown
    could try that. just need a few couplings.
