Offset for baseboard
Patchogue Phil_29
Member Posts: 120
It is ugly, but will be behind the cover and endcap.
I don'ty think it will be noisy but I want to hear some opinions if it will be.
Wish I had some PEX...
Will this be noisy?
Baseboard in bathroom. Walls used to have thick tile. Remodeled without tile on wall, so baseboard riser is too far into the room. The covers will not go on without moving the riser or making an offset.
Will my offset make a lot of water noise? Pump is a 007 Taco.
its xtra ugly but will work o.k. as long as it don't leak.0 -
phil
Why don't you use a piece of soft tubing, or make some by annealing it.
Robert O'Connor/NJ0 -
THEY HAVE 3/4" FLEXIES FOR THIS...NOT CHEAP BUT STILL...0 -
flexies?
What's that?
- 121 Chimneys & Flues
- 15.8K Strictly Steam
