Welcome to the wall
scorp_2
Member Posts: 1
Professor I installed a pilot retrofit kit into a furnace. The pilot light fine. The pilot does not have a thermalcouple in it. My problem is that burners are not sensing the flame. But I don't have anywhere to put the thermalcouple. Does all pilot applications need thermocouple? What else can be the problem be?
Welcome to the Wall
Hi Carol,
I've enjoyed your writing and have learned alot from you. Glad to see you here and I hope you have lots of spare time - this place can become additictive.
Thanks for taking the time
Tom
My opinion
If your burners are lighting, then going out you probably have a Dc flame rectification set up. This requires a flame rod at the pilot burner in this case. Be careful though you want this to work right. What type of ignition module do you have (if any) and what type of gas valve? Is it spark ( which I think it is) or standing pilot system? There are t-couple applications, Dc rec. and mercury switch. All depends on what type of ignition you are using. I also pray that you didn't install a pilot on a direct fire application. Give us all the info you can...Mod/furnace G.V., Ign Mod. etc...0 -
check onew condens boiler gust came on the marcket.IT has all you need for installation.veb site is www.go4elite.com0 -
Mike?
Ah,..Huh? Im not sure what you are saying to the last post or 2. Can My eyes be that bad?...lol0 -
thanks much.0 -
Hi Carol. I try to come to the wall for help and see whats going on, now I can get ahold of another industry pro.
Thanks Carol for all you do. Talk to you soon. Stop down and see me some time.
TheFuture0 -
Thanks, Future.0
