Tube in fin radiators
Ira Brand
Member Posts: 3
Can tube in fin radiators be used with a steam heating boiler?
Tube in fin radiatros
Can tube in fin radiators be used with steam heating system?0 -
fin-tube
after three or so running feet you will probably need a return.0 -
Thanks, Bob Young, for the info. This tube in fin is a 6 foot baseboard radiator, with a U shaped, one copper pipe system with a return (after a U elbow) coming after an air vent which is at the furthest end away from the valve. Do I meet your " three or so running feet" return suggestion?0 -
steel fin tube
what you describe sounds like a used part of a hot water system. usually tube fin for steam is 1 1/4 " or 2 " steel pipe with steel fins. a run of more than 3 feet or so usually requires a return. six running feet i doubt would work without a return0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
