outdoor wood boilers
Glen
Glen Member Posts: 854
which heats via fp ht ex - hi temp baseboard, dhw - and then some distance away from house - a large 3 bay garage. 3 bay is radiant - with a three way valve temp control. These folks like it warm - and the system should provide enough heat. But regardless of all the inherent faults listed by Fred and others - as long as fuel prices - interest in non traditional heating methods will increase. IMO most folks oversize the wood boiler to the extreme - which then requires some sort of heat dump - if you don't want to over pollute your neighbourhood with low temp, acrid wood smoke due to a smoldering fire.
  • mgs
    mgs Member Posts: 5
    OUTDOOR WOOOD BOILERS
    Looking for a good piping schematic involving a open outdoor wood boiler and then converting the building to a closed system witht the use of a flat plate heat exchanger. The closed system involves radiant tubing. Wondering about the best way to control the radiant side of things. Any input is greatly appreciated.
  • Betz
    Betz Member Posts: 58
    Open Outdoor Wood Boiler
    Email me and I can send you some schematics on how to run your pex into your indoor building if you like.
  • outdoor wood boiler and radiant heating
    It is difficult to marry the needs of an outdoor wood boiler to the needs of your radiant floor heating system. the temperature requirements to keep the outdoor boiler happy, the temperature requirements to keep the outdoors happy, the temperature requirements of your outdoor wood boiler to keep your neighbors happy, all far exceed the requirements of any radiant floor heating system.
    In its simplest form, the marriage between open and closed heating systems looks piping wise exactly like a system in which a cast iron boiler gets connected to an O2 porous radiant floor heating system. Force the open system water through one side of an appropriate heat exchanger and the closed side through the other. An automatic (read motorized) mixing valve and controller looks after the building heating needs. Remember though that the outdoor boiler is not a sophisticated heating appliance and remember to that when the heating and DHW needs have been met you cannot turn the wood fuel off as you can with a gas or oil appliance.
    At best this is an unequally yoked arrangement and should be avoided.
    We have discussed this topic on previous threads. Look in the archives.
  • RadPro
    RadPro Member Posts: 90
    Wood Boilers -Some of my distant
    neighbours have nicknamned there outdoor boilers the Steam engine since the smoke is rolling downwind pretty much 24/7. Makes agreat garbage incinerator aas well.Also have read Gov .reports stating real efficiency is less than 25 % but if you get free wood these might be for you....
  • S Ebels
    S Ebels Member Posts: 2,322
    Just the ticket for you
    Look at Taco's new mixing station that has built in reset or setpoint control along with a flat plate type HX. Four pipe connections, program the control and plug it in, simple as that. Saves gobs of time and works great. The HX is good for up to 50,000 BTU load.
    The more standard method is to simply pipe the system as you normally would and substitute the HX in the place where the real boiler goes.
  • leo g_13
    leo g_13 Member Posts: 435
    Mark,
    try this website, not only is this a unit that looks like it may fit your app., the site also has a page of many other manufactures, so you can do proper research.
    Leo G
