Basement Radiator / One Pipe Steam System
Bob Schultz
Member Posts: 38
This is what you will want to do.
http://www.heatinghelp.com/heating_howcome6.cfm
I am building a room/office in our basement and would like to tap into the existing one pipe radiator system to heat the room. Im thinking of installing a radiator 12"-18 above the water line so I can control it with a thermostatic air vent. Has anyone done this with success. Im a little worried about tapping into the vertical part of the return into the boiler? All comments welcome. Thanks0 -
basement rad
At 12"-18" above the water line, you will have trouble getting the condensate back to the boiler (not enough "A" dimension. You could install a trap on the radiator and install a small condensate pump, but how about installing a small FHW loop of the boiler. It would probably cost less to do and could be run as a separate zone.
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
