Underfloor heating, radiant tubes
Al Letellier_21
Member Posts: 400
It depends.....is the space below heated? If not, at least R19 is recommended. Less is needed for heated space. Fiberglass batt insulation works fine. Check with the manufacturer of tubing as to whether or not you need an air gap under the tubing
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I am installing radiant tubes, underfloor. Does any one know what kind of insulation I should use between the floor joists? There is room for R-38 (fiberglass). Do we use fiberglass, pink board, or reflective? Thanks! Howard0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
