Smokey Chimney
bob_46
Member Posts: 813
Short answer, yes.
I have a question about a running Viessman Vitorond Boiler .sort of.
Today I could see white exhaust coming from the chimney whenever it was burning. The boiler water temperature was at 140°F (there is an ODR installed) and the flue gases at the damper were about 160°F (measured via an infrared handheld.) The flue size is 5 in diameter and 17 feet high. Its an old brick chimney with a SS liner.
The temperature outside was 41°F, the humidity was 95%, and the pressure was 29.77 in.
Under these conditions, would it be normal to see smoke or the exhaust from the chimney? I know this probably sounds like a story problem I just want to make sure this is normal operation. Any info is appreciated.0
- 120 Geothermal
