If our community has helped you, please consider making a contribution to support this website.  Thanks!
what is this steam system?
                    DanHolohan
                    Member, Moderator, Administrator Posts: 16,672
                    standard air vents.
                Retired and loving it.
            What is this steam system
 I have a house built in 1920. The attached pictures show the steam system I have. It has three pipes! I do not now the purpose of the smaller pipe that runs all the way to the basement where it joins over a new boiler but is capped off. I am thinking a vapor system but want to confirm. A fitting on the side says "Enkin Brothers" patent in 1893. I am wondering if this can be turned into a regular two pipe system by adding some steam traps in place of the return valve, but first I want to find out what it is.0
            That's similar to a Paul system.
 The device removed the air from the radiators. You can replace them with standard air vents and keep the pressure low.Retired and loving it.0
 Thanks for the advice. Are you refering to standard one-pipe system air vents that I could find at a plumbing supply store, or something more specialized?0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
