Unused radiator caps
Mike T., Swampeast MO
Member Posts: 6,928
Why not remove the valve and install a cap on the pipe?
steam bath
Customer has removed several radiators by opening the union between the shutoff and the radiator. That's it. So if someone, like their little kid, turns on the valve, steam comes pouring out. That's gonna fry the little devil. Do they make a cap or plug that goes on the union fitting on the shutoff valve? It's 1 1/4" and the ring is on the radiator.0 -
Brass Caps
Should just be able to screw one of these puppies on...
http://www.plumbingfittingsdirect.com/brass1/40200.html0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
