best boiler for the buck
clammy
Member Posts: 3,242
If sticking with oil i would say a buderus g115 a very good unit service friendly with small features that do make a difference like excellent well insulated boiler ,no combustion chamber kit to replace , baffles to lower stack temp and very easy to get completly clean .And for gas i would do a condensing modulating boiler like a munchkin i believe it is a great value for the money i have installed a weil ultra and was not to impressed personally it's probaly a good unit but i did not like certain things about it .The big sale thing for me is that most chimmey do require a liner kit and by the time you add that into the equation of a conventinal boiler the direct vent munchkin has it beat plus they are very quite the t50 and t80 i reacentinstalled where very quite like a small refregerator .hope this helps peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Best boiler for the buck
Just did a new heat loss calc, figuring the changes since the old boiler went in in 1956. At 29,500 BTU/HR loss, I figure I'll need a 48K boiler. I am not looking for a unit with more bells and whistles than the Good Humor Man, but I would like the best bang for the buck. I like what I've heard about the Trinity . . . I've even thought of installing a Utica fixed-firing unit. To be honest, I am not sure what boiler I really want to use, and I have been putting this job off for several years hoping to find the right boiler to fill my needs. A few suggestion, please. I think I'll go with sealed combustion. My old boiler is oil fired and it's been in use since 1956, so I'd like to get away from the old chimney. Thanks0 -
Both Weil Mclane and Crown have been good to me...
T
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Just a guy running some pipes.0 -
keep your chimney, just add a liner. A chimney always works, 24 hours a day, seven days a week. A power venter doesn't. I chimney doesnt ruin the exterior of your home a power venter does.
Please keep your own chimney,.. for your own bennefit.
If you MUST powervent, I highly recommend System 2000
