how do you bleed a riello m5 burner pump. i dont see any bleeder
that`s the primary reset control, it may not be "red" now, but when its in operation, if for some reason it shuts-down on safety, that button lights-up. But for "bleeding-it", you can stop the burner by pushing-it, long enough to get the plug back-in!
i dont see any bleeder screw just plugs0 -
Riello........
Rick; It may not look like a "conventional" bleeder screw, it may be a plug, right below the regulator adjustment screw.0 -
that is how i tried to bleed it. didnt take plug all the way out just cracked it. didnt seem to get good flow though.0 -
Riello.......
You may have to remove-it(holding A can under it) and run it, it only pulls vacuum after the pre-purge cycle, when you get good flow you can stop-it by pushing and holding the red button-in, that way you can replace the plug.0 -
Thanks dave. when you say hold the button in i assume you mean reset button on control0 -
That`s the one........
unless you got really long arms, its hard to reach the switch to stop-it when it does come!0 -
i meant the reset button on the cad cell relay control (the gray box that goes to electrodes)0 -
Right..........
That red button lights-up if it shuts-off on safety, if you push-it and hold-it in, (after the oil gets to you), it stops the burner so you can put the plug back-in with your other hand.0 -
no red button that lights up. it is a riello gray controler with round button. on a pensotti boiler. if boiler locked out you would have to push button to reset.0 -
Riello..........
Its a big round "red" button on the gray control box right?0 -
yes, so i shouldnt need long arms right?0 -
thanks for your help dave. i will pull the plug under the pump adjustment screw and put my bucket under till i get good flow while tricking the cad cell eye with my flashlight and then when i get good flow i will hold reset button long enough to put plug back in. fuel line all bled . thanks again.0 -
Hope you make-out..........
OK, by the way, whats with the flashlight? The cad cell is mounted under the grey box, you have to remove-it to get-at it, so ya lost me there. Anyway, after your done bleeding, just pour your oil back in the tank.0 -
Flashlight
the cover over drawer assembly has a hole in it that if you use a flashlight to shine in will make the cadcell think its seeing flame0 -
Got ya Bruce.........
and Thanks!0 -
Dave....
Dave0 -
next time use a tiger loop combo...
the home owner is not going to salvage these thoughts through the ethers *~/:)0 -
Yup
Tigerloop Ultra the best buy in town0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
