Stairway switch
Jeff Roberts
Member Posts: 2
Is it possible to put a stairway switch and any type of firomatic switch on a gas steam millivolt system? I don't think so because of the added resistance in the circuit. But let me know please, I have a customer that has just purchased a house and 2 electicians have given her quotes to do the job. thanks for any help
I would,
think so Jim(electrical is not really my bag),I put-one on my HW boiler(millivolt) and just used a small relay mounted near the gas-valve.
Dave0 -
I would,
Dave0 -
Think so too
What is a thermostat but a remote switch? Just make sure you have enough mV left over to do the job at the valve...every switch (and wire) "eats up" a certain number of milli-volts through resistance.0 -
Red Switch
wall switches are put on millivolt fire log systems all the time, as for a boiler I would use a relay with millivolt contacts and a 24 or 110 volt coil. J.Lockard0 -
You may need to
add a 24 volt transformer so you can use a small control relay down by the gas valve. Find a nearby 120 volts source nearby and tap into that. WW
- 120 Geothermal
