More issues than readers digest thread
Jeff_129
Member Posts: 3
I am glad it was taken down, I didn't post that headache in the shower comment, although I thought it was funny. I quess anyone can change the author name.
Is it just me or
what happened to the more issues than readers digest thread
The subscription was cancelled. "Past issues" can be viewed over at oiltechtalk.com for the time being
Lots of threads have removed
by moderator but title remains would be nice if they did that here
NEVER UNDERESTIMATE DANNY DELETO!!!
Danny Deleto, Mr Holohan himself! He has the power and the glory to remove any post. They are usually more entertaining than the dreck that haunts this site. Unemployed egomaniacs communicating with loners, where do I sign up? OTT is a superior site ask Constantine0 -
It's true.
I dump the nasty stuff. Always will.
Love the nickname. Sounds very space age!Retired and loving it.0 -
Hello, I am the now infamous "Jeff's crazy Brother" which is true. The reason I have a combustion analyzer and a draft gage is because 7 years ago I had a new heating system installed and after reading the manual it required that the combustion be tested and gave a range of where those numbers should fall. I was home when the unit was installed and I was with the installer when he fired it up and no combustion test was ever done. I called him and asked him to do the test and got "the flame looked good" response. I tried to call several people other heating professionals and no one I talked with had an analyzer. So fearing for my family's safety and losing efficacy from this new boiler I went ahead and bought one. I also took a class to help me understand. I do test family members homes if the people working on their equipment don't have one, which is most. I don't fix the equipment I just tell them the numbers. Normally the numbers are listed in the manual, in Jeff's case they were not listed.
The reality is my experience 7 years ago and since then has jaded me to the heating industry. More than half the time I test after the equipment was worked by heating professionals the combustion numbers are out of range. The worst was when I checked my parents house 2 days after they had their boiler serviced. The CO locked out my analyzer and the draft was weak at best. They came back and "fixed the problem." I retested and got another lock out on CO. Now they are giving my Dad attitude because he's calling back. I sent Jeff here because his manual didn't have the numbers and he had the other issue as well.
I think the problem with his thread is people thought it was a joke and started posting answers as "Jeff" and were not the real Jeff and things went down hill from there. Now it may be true that Jeff needs a professional to look at his equipment. But how can he be sure he is getting one when 50% (I'm being generous here) don't set up equipment according to the manual specs and dont test combustion. It is very unfortunate for the many of you who are experts and take great pride in your work.0 -
Sounds like Frank from Philly.0 -
Sounds like an enforcer from the Sopranos
Danny Deleto.. 0 -
well,
all leg pulling aside, the ability to buy a scalple and take a class in first aid does not make you a doctor. I have spent 19 years in the heating trade and I have many many more to go until I know it all...LOL.. learning combustion is a art and should be considered one too. I would urge you to hire a pro and let them handle it from there..CO,Fire,Gas,and Hot water are best left to the guys who handle them everyday!0 -
Jeff's bro if you had taken the class
and I am not stating you did not. You would find readings that are standard on "types" of equipment. I got a chart when taking Jim Davis's class and it gave me readings for gas package, gas power burner and oil burner ranges along with other readings. The 4% o2 was good for an oil boiler or power gas burner but to low for a package boiler. the problem with the co is it was just one reading as stand alone it is acceptable. If one number of a rising count it is not acceptable.
Just posting the number does not tell me anything else but one very thin slice of the pie. I have to watch the analyzer performed for a given time and watch draft at the breach and in the flue and watch the temperature of the boiler and stack temperatures for the full picture.
So why didn't Jeff or you...
So why didn't Jeff or you follow my advice and post on the thread their location (i.e Bumport, New Jersey) so that people on this site could direct you to a real professional.
I did note that many heating contractors were not real professionals.
Many people here know it too.
Perry0 -
deleted.0 -
Thanks Mitch. By bro just brought some books over last night. I am looking at Jim Davis's "rule of thumb" for residential oil burners on page 30 of combustion analysis and diagnostics, but i don't understand or see info on what you call "package". The beckett AFG has a flame retention ring right? My CO level is steady and goes down at shut off.0 -
Your right, I sould have told him to post the start up, run and shutdown along with how stable they were. It would have given you a better picture.0 -
Package is actually a conventional
draft gas boiler I am off on the terminology because what I work on is typically a package boiler. It comes assembled uses stainless steal gas logs, made of cast iron and vents up a chimney using natural draft.
My bad on terminology.
You apparently know more than the average tech I see in the field but just like them, enough to be dangerous.
We were just dealing with an MIT graduate student, he was looking at a cut sheet for a toilet and could not figure out how to check rough.
Knowledge is one thing but it must be matched with experience to work properly.
What happened? I liked your post.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
