Hot Water pulsates from bathroom faucet
Trevor Baptista
Member Posts: 27
Thanks,
I took apart the faucet and put it back together. But I think the real problem was that the valve for the hot water under the sink was not all the way open. The problem is completely gone now.
Thanks again.
Thanks again.
Hot Water Problem
When ever I run the hot water in the bathroom faucet it starts to whistle then a loud banging occurs within the pipes and the water pulsates.
Please help!
Thanks!0 -
Not much to go on but
if it's an old two handle faucet it sounds like the screw has either loosened or disintergrated and the washer is vibrating.0
- 167 Indoor-Air Quality
