Hot Water pulsates from bathroom faucet
Thanks,
I took apart the faucet and put it back together. But I think the real problem was that the valve for the hot water under the sink was not all the way open. The problem is completely gone now.
Thanks again.
  • Trevor Baptista
    Trevor Baptista Member Posts: 27
    Hot Water Problem
    When ever I run the hot water in the bathroom faucet it starts to whistle then a loud banging occurs within the pipes and the water pulsates.
    Please help!
    Thanks!
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Not much to go on but
    if it's an old two handle faucet it sounds like the screw has either loosened or disintergrated and the washer is vibrating.
