copper to PVC
Harvey_2
Member Posts: 27
We are trying to connect Schd. 40 PVC from the pool to a heat ex. piped in copper. The thread connection always leak. We also tried sched. 80 male adapters. Whats the secret? Thanks
PVC to copper
I always use a female PVC adapter with a rubber washer inside and a male copper adapter, put pipe dope with teflon on the male threads and then wrap with 3 layers of teflon tape and assemble then glue the PVC.0 -
pool hx
When I did mine, I had the same problem- until I reread the literature which said to use 8" nipples if I remember correctly before changing to PVC. re- piped , and no more leaks. Mine was a WM, and all of their literature is online.0 -
lampwick
the secret is to use lampwick [ quickwick] on the threads with tellon or pipejoint compound. leaks disappear0 -
lampwick
the secret is to use lampwick [ quickwick] on the threads with teflon or pipejoint compound. leaks disappear0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
