copper to PVC
Harvey_2
Member Posts: 27
We are trying to connect Schd. 40 PVC from the pool to a heat ex. piped in copper. The thread connection always leak. We also tried sched. 80 male adapters. Whats the secret? Thanks
PVC to copper
I always use a female PVC adapter with a rubber washer inside and a male copper adapter, put pipe dope with teflon on the male threads and then wrap with 3 layers of teflon tape and assemble then glue the PVC.0 -
pool hx
When I did mine, I had the same problem- until I reread the literature which said to use 8" nipples if I remember correctly before changing to PVC. re- piped , and no more leaks. Mine was a WM, and all of their literature is online.0 -
lampwick
the secret is to use lampwick [ quickwick] on the threads with tellon or pipejoint compound. leaks disappear0 -
lampwick
the secret is to use lampwick [ quickwick] on the threads with teflon or pipejoint compound. leaks disappear0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 985 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
