New Boiler
kevin coppinger_4
Member Posts: 2,124
one very good option would be to do two boilers and stage them so as to jack up the AFUE....plus if 1 broke you would have a backup... kpc
PS...lots of good choices Burnham, Smith and Peerless
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Who Makes The Boiler I'm Looking For?
Hi, I'd like to replace my old boiler (Portmar,548 MBH, from the'50's/ Carlin 301 CRD/ 3.5gph 60 degree nozzle) with a more energy efficient model. I havent run the calcs yet, but I assume I'll be looking at something in the 300 MBH range. Only thing is, everything I've seen has a AFUE rating below 84%.
I manage a 5 story tenement building (25 X 55) with lots of old tenants and cheap rents. I don't mind paying more for the new boiler if it'll cut down on long-term heating costs. Any suggestions?0 -
I forgot to say- #2 Oil - Steam Heat
-Jon0 -
Smith
A Smith 19A-3 MIGHT fit the bill at 297,000 btus, but without an actual heat loss to work with, I would SUGGEST a 19A-4. The old boiler was considerably larger than 300,000.
The existing Carlin 301 may be re-usable in the new boiler with some minor updates. Talk with your heating professional about this.
If you have any further questions, please feel ree to e-mail me directly at GWoollard@Mestek.com.
Thank You,
Guy Woollard
Smith Boiler/ Mestek0 -
Self serving response
The Vitola 200 VB2-63 is rated at 87.1% AFUE. It develops 258MBTU. As a low temperature boiler it behaves as a much larger boiler. I'll bet a good mechanic like you can squeeze it a little more.
Thinking completely out of the box, consider a Weishaupt modulating burner for this set-up. The Vitotronic 300 controll supports modulating burners as well as LON communication if that is useful in your case.0 -
sorry, I had not yet gotten to your qualifier
Sorry, this is not a steam boiler. I just got ahead of myself.0 -
Fred
What do you think of the Vitoplex 100. I don't know about these EuroSpecs, kW? How does that translate into BTU/Hrs?
Any other ideas?0 -
metric conversion for Jon
25 Btu = 0.0073268 kilowatt hour
Don't know anything about the Vitoplex yet except that it is not in the
pipeline.0 -
Thanks Fred
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
