im needing a new set of
Maine Ken
Maine Ken Member Posts: 531
It depends... What areas do you drive in? I have extremely aggressive treads with studs on all four wheels. I drive on ice covered backroads and all around crap all winter long. I only get two seasons out of them because of the softer rubber. It is an expense well worth it. I only get stuck when I forget to think before engaging drive mechanism!!!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=346&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • truck tires...
    Im needing a new set of tires on my service truck. I still have the factory installed crap and anyone have any recommedations or experices? Thanks for your inputs and Happy Holidays to all.
  • Brad White_191
    Brad White_191 Member Posts: 252
    Toyo
    I had a set of Toyo tires (not sure if they are affiliated with Toyota or not), put on my 1987 Toyota xtra-cab pickup after the original factory set failed inspection. That was at about 45,000 miles.
    I kept the Toyo's until the truck died, Christmas Eve 2001 just 40 miles shy of 200,000 miles and the tread still looked sharp, at least enough to pass inspection.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    For snow....
    Bridgestone Blizzak.
    The best snow tire I have ever driven on.
  • Maine Ken
    Are those available in load range E? I have used them on an escort in the past and they were wonderful tires.
  • TimS
    TimS Member Posts: 82
    Tires the only thing between you and the road.
    I'm driving rear wheel drive 3/4 ton van have goodyear prograde load range E. 11 months old great all around impressive in snow recently. I did notice 1 MPG loss when I got them . I'm sold plan to buy 4 of the Silent Armor Goodyear for my burb soon.
