im needing a new set of
Maine Ken
Member Posts: 531
It depends... What areas do you drive in? I have extremely aggressive treads with studs on all four wheels. I drive on ice covered backroads and all around crap all winter long. I only get two seasons out of them because of the softer rubber. It is an expense well worth it. I only get stuck when I forget to think before engaging drive mechanism!!!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=346&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
truck tires...
Im needing a new set of tires on my service truck. I still have the factory installed crap and anyone have any recommedations or experices? Thanks for your inputs and Happy Holidays to all.0 -
Toyo
I had a set of Toyo tires (not sure if they are affiliated with Toyota or not), put on my 1987 Toyota xtra-cab pickup after the original factory set failed inspection. That was at about 45,000 miles.
I kept the Toyo's until the truck died, Christmas Eve 2001 just 40 miles shy of 200,000 miles and the tread still looked sharp, at least enough to pass inspection.0 -
For snow....
Bridgestone Blizzak.
The best snow tire I have ever driven on.
Are those available in load range E? I have used them on an escort in the past and they were wonderful tires.
Tires the only thing between you and the road.
I'm driving rear wheel drive 3/4 ton van have goodyear prograde load range E. 11 months old great all around impressive in snow recently. I did notice 1 MPG loss when I got them . I'm sold plan to buy 4 of the Silent Armor Goodyear for my burb soon.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
