Tekmar/Gateway?.....PC
if you want control over the modulation in the same unit, that's about it.
what is it you are trying to do remotely?
PC.........or only mini mac/apple
Hey........anyone know of a pc(windows)freindly interface from remote location with GB142....or is the gateway it?
Thanks0 -
thankyou
sorry for vagueness.........homeowner would like to be able to setback and forward temperatures in a multi zone radiant heating system from remote location.preferably from a pc at other locations geographiclly.
mike0 -
well, the gateway allows that: the only thing that has to be a mac is the server at the house, you can log on to it with any web browser from any computer.
But if all they want to do is change temperature remotely, there might be something from smarthome, try this:
http://www.smarthome.com/_/ProductResults.aspx?Ntt=internet thermostat
that's just a search for "internet thermostat" over there. I've never used any of it, but it might do the job if you don't need super fancy hydronic controls. though by the time you do a lot of zones, you may find tekmar to be cost effective..0 -
remote adjustments are by way of a web site portal, so mac/pc/cell phone...however you access the internet will work. Only the gateway needs to be a mac.0 -
I'd contact a honeywell, they may have something. The AQ2000 zone controls are very Tekmar like, there may be an internet interface available.0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
