Condensing boilers in the U.K. (Dan H.)
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
an interesting e-mail from a U.K. homeowner who told me that ALL new boilers installed in the U.K. must now be condensing.
Retired and loving it.
  • John Ketterman
    John Ketterman Member Posts: 187
    Those rules have been in place since October 2005.
    But of course, you can buy a condensing boiler for under $1000 there:
    [A] http://inspiredheating.co.uk/acatalog/Potterton_Suprima_HE_Boilers.html
    [/A]
  • John Ketterman
    Those rules have been in place since April 2005.
    But anyone can buy a condensing boiler (just the boiler) for about $1000 there:
    and even a Buderus is only slightly more money:
    http://inspiredheating.co.uk/acatalog/BUDERUS_600_REGULAR_RANGE_CONDENSING_BOILERS.html
    I realize that installation labor is most of the final cost. Still, why are condensing boilers significantly more expensive in the US?
  • DanHolohan
    Perhaps
    economies of scale?
  • bob_46
    bob_46 Member Posts: 813
    Pitkin county
    colorado requires 92% or better.
  • Uni R_2
    Uni R_2 Member Posts: 589
    Marketing
    Like Dan said, ecomies of scale but even more so you have to keep in mind that the wall hung market over here is still a developing market and we're still way behind. Until the market matures, the prices will remain high. We have to remember that in Europe a large percentage of new boilers will hang in almost the exact same spot as the old one, even if they changed brands. We are still just putting in the first generation of wall hung boilers in homes.
    That's the major regret I have with most of the manufacturers selling to the North American market. They aren't preparing for the inevitable. These will become appliances and their life spans will be shorter than the cast iron carrier anchors that we are used to.
    As appliances, they should have certain form factor considerations to facilitate easy changeouts. The European models tend to all coaxially vent from roughly the same spot (Kudos to the Burnham Freedom for the venting!) and this can be seen on the Baxi and Vitodens. Who knows, maybe coaxial venting was designed to allow sealed combustion boilers to be installed where there was just a simple vent hole before? They all tend to have their connections on the bottom with the return to the right side and the gas in the middle. I would guess their swap out costs are much cheaper as well since the new unit vents through the old hole and the piping justs needs a small adjustment in the vertical rise to connect to the boiler.
  • Andy Byrnes
    Andy Byrnes Member Posts: 42
    All new installations have to be band A or B rated boilers. Both are condensing but band A been the most efficient. Band B tend to be similar to your common boiler but with a recuperate in the flue duct system that extracts the heat in the flue.
    There are exemptions to this. They have created a points system where if the position of a condensing boiler is impossible than an ordinary boiler( Band D ) can be fit.
    If the boiler has to be moved because the flue is directly over the boundary of the neighbouring property so many points are awarded. If it’s difficult to run the condensate again points are awarded.
    We have flats with internal flue systems ( SE ducts ) again the are exempt.
    But this is only in England and Wales but I think Scotland will follow suite soon.
    Manufacturers are now at last producing high quality reliable condensing boilers but probably because the market has demanded it.
    Andy B.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Euro vs US costs
    Some reasons for increased costs for Euro boilers:
    1. The boilers must be converted from 240v 50Hz to 110v 60Hz. Not to mention metric to US fitting conversions. This costs $$
    2. The value of the US dollar against the Euro
    3. Shipping costs from Europe to the US
    4. Technical support and training costs
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Last time I looked they had a broader range of sizes (smaller) available as well.
    Equipment cost is definitely lower than in the US (as Dan said, like economics of scale and lower shipping costs), but installation is like quite expensive. UK plumbers make quite good money--believe £100,000 is around average. Considering their piping connections, a good chunk of that pay may go to psychiatrists, beer or liquor...
  • Weezbo
    Weezbo Member Posts: 6,231
  • Solarstar
    Solarstar Member Posts: 81
    AS quoted in 2005
  • Andy Byrnes
    I wish we earned £100,000 in the UK .In the north around yorkshire the average wage of our repair men is about £25,000 to £30,000. In London you could expect to earn more but the price of property is stupid.
    Andy B.
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Thanks Andy !
    Just goes to show that plumbers and heating techs are THOUGHT to CHARGE too much...but most isn't really going into their (OUR) pockets. I wish the customer understood that part. JMHO. Chris
  • Jed_2
    Jed_2 Member Posts: 781
    Didn't read the links, but
    Are the "boilers" sold in U.K. and Europe for these prices "H" stamped equivalent as classified boilers ( $$$ to get that in the U.S.), or water heaters? What added costs to market, sell, and install these "boilers" in the U.S. adds significantly to "value added" costs? After all, it's old hat in Europe, isn't it?
    Jed
  • Weezbo
    Andy , do you have time to tell us about CORGI and IPHE
    and maybe what jumping through the hoops for a typical residential permit for an up grade to a condensing unit might entail?
