Mobile Home heat pump?
Bernie Riddle_2
Member Posts: 178
first where do you live and how old is your home, answer these 2 questions and i will be glad to give you some advise
Peace Be With You
David C. Broome
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=390&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Peace Be With You
David C. Broome
Hello all, i am looking at changing from an oil furnace to natural gas furnace and was wondering if a heat pump could also be used like most new homes around here are using?
thanks for all replys0 -
Hello Dave, thanks for your reply
Lower mainland in B.C. which is the same climate and weather as Seattle. Home is 24 years old but has been extensively rebuilt with 2x6 exterior walls, thermo windows and 10 inches insulation in the attic now.0 -
You may want to install a high efficient heat pump for primary and a gas furnace as secondary. I have installed many systems like that and they work great. Be sure to have an outdoor thermostat installed so it switches over at the set temperature.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
