Mobile Home heat pump?
first where do you live and how old is your home, answer these 2 questions and i will be glad to give you some advise
Peace Be With You
David C. Broome
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=390&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Jackson_2
    Jackson_2 Member Posts: 1
    Hello all, i am looking at changing from an oil furnace to natural gas furnace and was wondering if a heat pump could also be used like most new homes around here are using?
    thanks for all replys
  • brad_14
    brad_14 Member Posts: 25
    Hello Dave, thanks for your reply
    Lower mainland in B.C. which is the same climate and weather as Seattle. Home is 24 years old but has been extensively rebuilt with 2x6 exterior walls, thermo windows and 10 inches insulation in the attic now.
  • RianS
    RianS Member Posts: 104
    You may want to install a high efficient heat pump for primary and a gas furnace as secondary. I have installed many systems like that and they work great. Be sure to have an outdoor thermostat installed so it switches over at the set temperature.
