fan control center
What where you looking for? Information on a particular one?
fan control center
fan control center
looking for site or info on fan control centers,yes im a tech, bit i need more on this subject.thanks. maybe ill be able to help someone on some other topic0 -
Just a thought
Usually all the info you need is on the instruction sheet. Maybe you have something a little confusing.:-)
Mike T.0 -
fan control center
Is it a transformer-relay combo with N/O N/C terminals? They could be used to provide Domestic Hot Water Priority back in the day. Johnstone Supply, Graingers, etc. has them. Get a suggested wiring diagram from a new one. Sometimes the relay contacts get flaky and they don't work anymore.0 -
Here's a couple of files...
that should help you out.
http://customer.honeywell.com/Techlit/pdf/60-0000s/60-1190.pdf
http://customer.honeywell.com/Techlit/pdf/69-0000s/69-0482.pdf
Hope they help.0 -
thanks all0
- 167 Indoor-Air Quality
