Flush Toilet... Pipes Bang
Rob_39
Rob_39 Member Posts: 9
Sometimes when the toilet gets flushed several seconds later we hear some banging on pipes...this doesn't happen all the time, just occasionally
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Try
    closing down the valve a little that feeds the toilet to fill the tank slower. It could be that your ballcock is bouncing some from the water pressure and volume.
    Jack
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Try
    more fiber in your diet.
  • Rob_39
    banging
    The pipes that bang are in the basement
  • Jason_22
    Jason_22 Member Posts: 39
    Water hammer
    In any water hammer situation you first need to check the incomming house pressure.It should be around 60 psi. Fix this first, it could be the only problem. Hope this helps.
  • Rob_39
    how to check
    Where/how do I check this pressure?
  • jp_2
    jp_2 Member Posts: 1,935
    easiest to start
    do what jackchips suggested, easiest solution.
    you can probably get a pressure gauge that goes on an outside hose bib.
    the problem could also be as easy as the basement toilet line loose and clanging on something.
    but what jack suggested would work
  • SVDW
    SVDW Member Posts: 80
    First step is to go downstairs & have somebody flush the WC so you can identify if it's a supply or waste pipe banging. If it's a waste pipe fasten it securely & test again. If you have supply line banging adjust the ballcock vlv as previously suggested. You might try closing the supply valve a bit as well. If that doesn't do it get a water hammer arrester such as a Precision Plumbing #MM-500ASCP. This will replace the supply stop & has an integral hammer arrester. (Water hammer is caused by a valve suddenly closing & abruptly stopping flow through the pipes. It can be annoying & even crack piping.)Probably will not find one in a big Box store but any plumber should be able to get one & install it for you. Don't just live with the noise, eventually whatever is moving will probably crack/leak & then you'll still have to fix it after you clean up the mess! Good luck.
  • JB_8
    JB_8 Member Posts: 85
    noise
    It could be very cold water replacing warm water and the pipe expands. If its in the winter only that may be the problem. The clamps on the water pipe in the ceiling are to tight.
  • gman_4
    gman_4 Member Posts: 12
    sounds like water hammer
  • tony_27
    tony_27 Member Posts: 1
    banging pipe
    all these suggestions sound correct.you can also check to see that if the angle stop at the toilet is not open all the way the water passing by the washer can cause the washer to vibrate violently and cause all kinds of banging.i have seen this problem a number of times
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Pressure gauge setup is easy
    At hardware store or box store:
    1-female hose bibb x 3/4" or 1/2" female thread adapter.
    1-3/4" or 1/2" x 1/4" threaded bushing.
    1-0-100 (or whatever) pressure gauge, 1/4" male thread.
    That's all I've ever used.
