whats a mod con?
brucewo1b
brucewo1b Member Posts: 638
A mod-con is a mod con but a mod con is not always a mod-con
  • Jason_19
    Jason_19 Member Posts: 17
    Whats a mod con?
    whats a mod con?
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Mod = modulation = the ability to match heat output to heat loss.
    Con = condensing = the ability to extract the energy contained in the water produced by combustion before it exits the flue.
  • John Ketterman
    John Ketterman Member Posts: 187
    Especially in the UK, it can mean "modern conveniences", as in "This house has all the mod cons". So a mod-con boiler is a mod con.
  • Could be a conservative moderate living in a new house...
    In which case you'd have a Con-Mod living in a mod con living with a mod-con...
    Sorry, could NOT resist:-)
    ME
  • ttekushan_3
    ttekushan_3 Member Posts: 965
    mod con
    Okay, can't help myself-
    A mod con is the bad guy on this program:
    Terry T
  • scott w.
    scott w. Member Posts: 226
    I thought a mod con was that nice guy from nigeria using the internet to share the wealth with the unsuspecting.
  • Weezbo
    Weezbo Member Posts: 6,231
    contrary to popular belief it is not a modern confabulist...
    the words that are being used are real and do have meaning :) it just sounds like a foreign language *~/:)
