gas fired flu vented hot air heating system
I have a hot air furnace in the basement and it is flu vented to outdoors, shouldn't this furnance have a filter?
  • Charles G.
    Charles G. Member Posts: 113
    Gas furnace
    Yes.
  • Empire_2
    Empire_2 Member Posts: 2,340
    Absolutly as CG stated
    If there is not, "Buffalo Boot can be installed to provide a slot so it can be easily changed by the home owner. Now is the perfect time to call a Pro to evaluate you current HVAC system and make recommendations and remedy any problems....
    Mike T.
