gas fired flu vented hot air heating system
steve_135
Member Posts: 1
I have a hot air furnace in the basement and it is flu vented to outdoors, shouldn't this furnance have a filter?
Gas furnace
Yes.0 -
Absolutly as CG stated
If there is not, "Buffalo Boot can be installed to provide a slot so it can be easily changed by the home owner. Now is the perfect time to call a Pro to evaluate you current HVAC system and make recommendations and remedy any problems....
Mike T.0
- 167 Indoor-Air Quality
