New Heating system
ALH_4
ALH_4 Member Posts: 1,790
Anything can be done. How easily it can be done depends on a lot of things. Access to run pipes from the boiler to the baseboards is important. Is the current boiler large enough to heat both units? If not, is installing larger venting an issue? To know with any certainty how difficult this could be, you should call a <a href="http://www.heatinghelp.com/getlisted.cfm">professional</a> to take a look and give you an estimate if the switch looks feasible.
-Andrew
  • Jenneyanydot
    Jenneyanydot Member Posts: 1
    change heating system
    I would like to know if it is possible to change from gas hot air to baseboard hot water. I have 2 family and the main apartment has baseboard the downstairs apt has hot air. we would like to make downstairs baseboard. Thanks
