New Heating system
ALH_4
Member Posts: 1,790
Anything can be done. How easily it can be done depends on a lot of things. Access to run pipes from the boiler to the baseboards is important. Is the current boiler large enough to heat both units? If not, is installing larger venting an issue? To know with any certainty how difficult this could be, you should call a <a href="http://www.heatinghelp.com/getlisted.cfm">professional</a> to take a look and give you an estimate if the switch looks feasible.
-Andrew
-Andrew
change heating system
I would like to know if it is possible to change from gas hot air to baseboard hot water. I have 2 family and the main apartment has baseboard the downstairs apt has hot air. we would like to make downstairs baseboard. Thanks0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 771 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
