12 Cylinder Diesel
at 1660 gallons of fuel per hour, just think how big the fuel tank(s) are
  • brucewo1b
    brucewo1b Member Posts: 638
    12 Cylinder Diesel
    This was a web page sent to me just thought I would share, not exactly heating but mechanical things this big do impress me.Diesel
  • rumn8r
    rumn8r Member Posts: 105
    102 RPM...
    Wonder what it sounds like at an idle.
    In one of the pictures near the end of the crank with the ring gear on it, I can see what looks like the starter motor. Obviously, they have a decompression for start feature. Wonder what the battery bank looks like.
    All of the cruise ships I've been on in the last 7 years are diesel electric. The shaft motor is a reversible variable speed electrically driven motor. Wonder if these big guys are follwoing the same trend.
    Technology, In't it sumpthin'!
    Thanks for sharing.
    ME
  • Uni R_2
    Uni R_2 Member Posts: 589
    Torquey...
    They're pretty torquey for a Japanese engine! ;-)
    5 million foot-pounds of torque!
    And all it needs is bunker crude / sludge to run on...
    Thanks for sharing Bruce! I love the staircases leading down to the bottom of the crankcase in each cylinder. The scale is unreal.
  • Weezbo
    Weezbo Member Posts: 6,231
    that would take a Large can of STP motor honey for the bearings
    Plastigauge for it must look like a Rope :)
    Harahito. Bring the 175 and 3/4's over here. We have to tighten up this head bolt":)
    "That's the 177 and 25 /32nds Shallow Well! :) i am going to have to send you back to American Tape measure reading class." on second thought, go get the 225 ton overhead crane and bring the Rocker cover gasket over :) "
    that thing must be a real challenge to assemble...
    think of the Impact wrench:)
  • Seattle Nick
    Seattle Nick Member Posts: 64
    I wonder how they forge a crank that big!
    That engine probably uses compressed air directly to the cylinders to start,Mark, something along the lines of what is described HERE on these "tiny" submarine diesels :)
    The electric motor in the photo may be just for turning the crank while they are erecting it or for servicing later on.
  • hr
    hr Member Posts: 6,106
    Power to the people
    wow, nice artcle.
    Diesels are in the news a lot these days. A JCB powered streamliner set a new record at Bonneville this year. Dual 4 cylinder backhoe engines! Not to mention Audi's wins and a Peugeot 700 hp V12 5.5 liter oil burner.
    And now LSD at the pumps! (low sulpher diesel)
    hot rod
  • LarryC
    LarryC Member Posts: 330
    Jacking gear
    That motor is probably the jacking gear. They use motors to rotate the propeller of large ships slowly to minimize warping of drive shafts and probably to allow the engine to move slowly to equalize the heating of all cylinders after shutting the engine off.
    Larry C
  • Maine Doug_51
    Maine Doug_51 Member Posts: 23
    Thanks for the link
    The FM engines are on the tugs that I get to ride in sometimes. Mt neighbor is an engineer and captain.
    Last month I toured again the sub in Baltimore harbor, by myself since it was end of season. Cool stuff.
