Flex dryer vent = frustrating!
Ken C.
Member Posts: 267
I dread whenever I have to deal with aluminum flex vent for a gas clothes dryer (I'm talking about the stuff that's similar to a Z-vent chimney liner). I always have a hard time getting it over a 4" smoke elbow or a vent terminal. The stuff tears very easily, and, especially annoying, it tends to tear in a spiral.
The other type of flexible dryer vent (the aluminum foil supported by a spiral of hard wire) is much easier to work with. It slides over smoke pipe and fittings without a struggle, but, unfortunately, it does not meet code for venting a gas clothes dryer.
So, I have to use the code-approved flex vent, but wonder if anyone has any techniques to make working with it less frustrating...
I need to keep what's left of the hair on my head! Thanks.
have you tried crimping the 4" hard pipe,that worked @ my house.0 -
you would...
probably be better of using 30 ga. hard pipe and elbows....kpc
It may cost a bit more
but on my own I use 4" duct and elbows, less fight and stays cleaner longer.0 -
foil tape
I always foil tape where I need to cut it ( or stress it in any way )...before hand. Also , there is a heavier gauge available at sheet metal supply houses that is much more durable. Longer crimpers help to make better " small ends " also on this stuff ( I roll the edge out with my thumb for " large ends ". Don't forget to " crush " the overlap seam on hard metal pipe when crimping ( the edge can fold out if you crimp close to it ). Worm drive clamps ( large hose clamps ) work good for dryer vents ( no screws sticking inside ).0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
