plumbing problem
Christian Egli_2
Member Posts: 812
The fourteen seconds solution will do the trick.
That was hilarious :) Thanks Brad.
Plumbing Problem
Was hoping someone could help me here. I am having a drainage problem, a blockage of some kind it seems, in one sink of my double sink bathroom vanity. It seems only to take place in the morning when I am shaving and brushing my teeth and no one is using the second sink. I can't figure it out but it maybe a black and white issue for the seasoned professional "wallie". I am hoping you guys can help me before the problem becomes catastrophic and I have to call in the plumber. If you guys come through it would be the cats pajamas. I have attached a picture that may help in the diagnosis. Thanks0 -
I've got the purrrrfect solution, shave your cat.
calling the vet
Calling Vet Brad White... What u make of this?0 -
Brad
is somewhere between earth, heaven and the dwarf planet.
The solution I would offer as both a plumber and designer-Rover.
Jack0 -
u mean the
U mean the Rover-rooters?!0 -
this requires a little known trade secret
you cant use a snake on that type of blockage...i could come over buh you can DIY ina pinch....First you will need a small 4 fingered dude known as a Hamster *~/:) there are few gaurantees in life buh this is one of the just about sure fire ways to increase flow in this instance..Trust me on this one..:)0 -
Get a dog...
and train it to keep the cat out of the sink...:-)
My two dogs take turns locking each other out of the room, or in other rooms. Funniest thing you've ever seen. The punting dog walks out of the bedroom, and the hunting dog gets up and closes the door behind him.
Some how the other night, the punting dog locked the hunting dog into my office down stairs...closed and latched the door on her while she was hiding from the thunder.
Some peoples pets...
ME
ME0 -
The problem is widespread.
As evidenced here ;~)0 -
that's why
we should be installing hair traps on all lavatory sinks!
Hey ME, that might just be Tickles who was, on a dark and dreary April 1st, trapped in some ductwork???
Would that be a Cat-a-gory 5 clog?
I volte for the (H)Air-Force (CO2-charged) clog-blaster. A clear pathway must be maintained for this type of clog as their exit, when blocked by frail human flesh, will not be denied!
As for shaving a cat? The culprits will get caught if that cat belongs to a teacher and they fail to wear protective gear. Don't ask me how I know that. Let's just say that electric shavers & cats are not a good mix.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
